#862418 02/04/04 03:35 PM
I have two steering issues
1. if I let go of the steering wheel the car pulls to the left - alignment problem?
2. at low speeds the steering wheel has a continous wobble that goes away at higher speeds.
I also notice this wobble after a trun as the wheels are coming back to straight.
Checked the steering fluid level - seems OK.
Any ideas, is this a simple balance the wheels and alignment or is it a steering / suspension problem.
96 Mystique V6 2.5L Duratec Unfortunately ATX, 150K+
#862419 02/04/04 03:46 PM
N
N
Bent rim
Bad tire
Wheel bearing (is there a sound to it?)
#862420 02/04/04 11:06 PM
H
H
Well it isnt a rim, that would be worse at higher speeds because the wheel would be going faster.
CV jounts/boots, would be a cause of that, or any damaged component of the steering and or suspension.
With the car pulling to the left, I would go to Belle Tire for that alignment, they do a very good job of doing them on Contours and it is done right the first time.
#862421 02/04/04 11:35 PM
Ball joints/Tie rod ends
#862422 02/05/04 01:39 AM
check for tire balance and allignment. it might be a bent rim hit any curbs?
1999 Ford Contour SE Zetec with 137k miles. AIM Name: ContourAlf Yahoo IM: Contour_Freak
#862423 02/05/04 03:28 AM
Ditto, & possibly a wheel bearing, but it would have to be aufully bad to wobble. A bearing that bad would be moaning like my girlfriend too. (don't tell my wife)
