Having owned both a '95 and a '96 V6 Contour, I have noticed something rather interesting.
I have had the check engine light come on for a "lack of oxygen sensor switch indicates lean" on both cars.
All the times it happened (4 that I can recall), I was travelling at highway speeds of ~70MPH or more.
2 of the times that it happened, I had been driving at highway speeds for 2-3 hours or more. The other 2 times, it happened after about 20-30 minutes of highway driving.
2 of the times that it happened, it happened shortly after I accelerated onto a highway (from another highway, or from a short stop after highway driving)
I have never gotten this code during around-town, stop and go driving. It seems that only sustained high-speed driving makes it happen.
In the case of the '95, replacing the oxygen sensor made the code go away. For the '96, I have not yet replaced the oxygen sensor, and it's possible that isn't the problem, BUT the check engine light came on under the same conditions that it did on the '95, so I think it's very likely that the oxygen sensor IS the problem.
While I am on the subject, is the bank 1 (firewall side) oxygen sensor on the '96 as easy to replace as it is on the '95? On the '95 all I had to do was remove the coil pack, and use an oxygen sensor socket with a U-joint and an extension. I think there might not be enough room on the '96 for an oxygen sensor socket???
