Posts: 211 |
Well, this morning I was stuck in the snow so I tried to get out by rocking the car back and forth by shifting from 1st to reverse quickly and repitidly..... Well after getting out I made my way 15 miles to work and on the way home I noticed I was having a hard time shifting and about 1 minute later the clutch pedal wobbled a bit and wouldnt go in gear at all... Any ideas???
Thanks in Advance....
1998.5 CSVT #3617
K&N Custom Intake
Custom 2 3/4 Magnaflow cat back
Ram HD Power Grip Clutch
Energy Suspension Inserts
Bosch Platnium +
Bf-Goodrich G-force radials "KDWS"
Alpine deck CDA-7863
Boston mids
More to come: Stock Sucks!!!!
Posts: 1,017 |
sounds to me like a cracked master cylinder
1995 SE
2.5L V6/MTX
187k
Posts: 211 |
1998.5 CSVT #3617
K&N Custom Intake
Bosch Platnium +
Boston mids
Posts: 1,145 |
there is something in the FAQ about it being hard to shift but i dont know about no going into gear, sorry if im not any help i dont have an mtx yet
98.5 Black SE ATX
Posts: 1,064 |
Originally posted by TommyBoy: Well, this morning I was stuck in the snow so I tried to get out by rocking the car back and forth by shifting from 1st to reverse quickly and repitidly..... Well after getting out I made my way 15 miles to work and on the way home I noticed I was having a hard time shifting and about 1 minute later the clutch pedal wobbled a bit and wouldnt go in gear at all... Any ideas???
I had the similar problem in Nov. Clutch pedal hit the floor then regain pressure a few sec later? My pressure plate exploded. Sorry to say it, but I think your clutch is gone. I had ford do mine since I do not have the tools to pull it off myself.
2003 Toyota Matrix
1972 Pontiac Ventura II "Sprint"
1998 SVT !SOLD!
Learned patience the hard way
Posts: 2,454 |
It is possible you burned up your clutch in the process. Can you change gears when the car is not running? If so, then you need to check out the clutch assembly. If not, then you need to look deeper into the trans as far as possibly breaking a shift fork pin or something along those lines.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 211 |
Yeah.. I can shift when the car is off but not easily.... When I try to start the car it try's to go forward as if the clutch wasnt depressed.. How much should I expect to pay for labor and parts fornew clutch and pressure plate?? It's kinda weird though.. Never had a problem with my clutch B4!!!
1998.5 CSVT #3617
K&N Custom Intake
Bosch Platnium +
Boston mids
Posts: 167 |
It sounds like your clutch. It will be around $1,000.00 to change it out with a stock replacement. How many miles on your car? Think of it as an opportunity to upgrade your transmission with a limited slip differential, lightweight flywheel, and maybe a performance clutch.
Posts: 1,064 |
My clutch went at only 54K, no signs of problems. Just went when I shifted gears.
2003 Toyota Matrix
1998 SVT !SOLD!
Posts: 9,602 |
I would have to agree with most of the assessments. It does sound like the clutch and/or pressure plate is damaged.
The stock parts DO NOT like repetitive use. They heat up very fast and the slip at best or outright fail at worst.
Depending on your available money and mechanical skill you could upgrade the entire setup (LSD, SPEC, Flywheel, 3 forks, syncros, etc) for about the same price as paying someone to just R&R the clutch with stock components. (OEM PP, T/O, & clutch) It is the labor that kills you!
Either way it would be extremely smart to upgrade to the better shifter forks and syncros (at least 2 & 3 for sure!) when everything was apart! It is not very expensive at all.
Upgrading to SPEC and a Torsen would be as well but that would be around $700 more vs just clutch R&R labor & a stock clutch set.
Whatever you do - DO NOT BE CHEAP!!! Replace all the clutch parts!
2000 SVT #674
13.47 @ 102 - All Motor!
