#859778 02/01/04 08:40 PM
cee Offline OP
if the cel light comes on and you fix whatever the problem was do you have to reset the cel or will it go away on its own since the problem is fixed????
#859779 02/01/04 11:54 PM
N
N
It should go away. The light stays on as the problem persists. In other words the system is always checking and when the error occurs, CEL.
But, it never hurts to unplug the positive battery cable for 20 or so minutes & the code will be gone.
#859780 02/01/04 11:59 PM
cee Offline OP
thanks
#859781 02/05/04 01:41 AM
if you have the code reader and you fix it or not you can clear the codes and they will come back after two or three cycles(runs of the car when the problem comes back) and if the car was fixed then the codes will not come back.. if you dont have the code reader to erase the codes you can take the battery cable off and the codes will go away.. you then run the car and the codes will come back on probably the next day if you dont have the problem fixed.....
#859782 02/05/04 09:44 AM
i just bought one of these obd II code readers. no more going to the dealership to see whats wrong.
2006 fusion sel 1998 grand prix gtp(wife) 1993 dodge shadow es(winter beater)
