#858762 01/31/04 07:02 PM
gregl Offline OP
I've got a 98 Contour SE Sport with V-6/5speed. Love the car, hate fixing it!
Problem is a) Interior lights stay on after starting, or stopping car b)Intermitent wipers don't work, and when activating wind shield washer no wipers c)Rear defrost doesn't work. I've read here before I joined that it's likely a Timer relay under the fuse box in the footwell. IS there a way to test the module before replacing it?
Greg 98 Contour SE Sport V-6/5 speed RAZOR shifter, custom console, custom grill Firestone FTX 225/60 R15 V rated
H
H
Welcome onboard.
Try self-test for Central Timer Module posted on this thread:
self-test
I feel your pain....
Welcome to CEG!
Former owner of a 1995 Ford Contour GL w/ 2.0L ATX Proud owner of a 2005 Ford Taurus SE 3.0L V6 Vulcan --Looking for Commodore stuff (Drives, Units, Amiga, games, etc)If anyone has any of this laying around and wants it gone, lemme know --
gregl Offline OP
Thanks for the info horsey. I tried the test using the defrost button, but got no results whatsoever. Any futher suggestions?
H
H
Chances are good it's the CTM but, as you will have noted from link I provided, there have been cases where faulty wiring at the interior fuse panel has led to symptoms similar to CTM failure.
BTW I presume your dome light switch is in 12 sec delay position.
gregl Offline OP
Yep, dome light is on 12sec delay. Killed battery 4 times before I figured it out. Footwell lights eventually burned out. I'll replace the module later this week and let you know. THanks for the help.
