Posts: 116 |
Where could i find licence plate lights (not bulbs) for my car - other than a Ford dealership? (they want $76.53 each). Both lights are so filled with corrosion it's sick. I need these bad. As far as i know they're a dealer only item. Any suggestions other than a wreckers?
Posts: 292 |
 Ford wants how much for each of those?! That's sick!
1998 Ford Contour GL Sport 2.5 V6 MTX in Black @ 322ks
BMW 335i = Lexus IS350 in your rearview mirror
Posts: 351 |
Just a suggestion, but you could try Canadian Tire.
ED
Black E0, 3L Hybrid. Long time ago...
It was fast. real fast...
I am Canuckian
I am Canuckian
Posts: 4,168 |
Any chance you can soak them in a chemical to get the salt and such out?
Green 96 mystique gs 4cyl mtx
16.9 in the 1/4 mile @102500 miles
95SE in Midnight Red MTX
MSDS headers and y-pipe
SVT exhaust
SVT UIM
Optimized se TB.
Full pre 98 SVT body kit
15.741 @ 87.73mph :)
Posts: 2,319 |
They're $41 US at www.fordpartsonline.com (plus shipping expense). GST/PST will of course also be payable on border crossing plus carrier's cod tax collection fee. Definitely a get-at-wrecker item if you can't clean-up your existing ones.
Posts: 116 |
thanks for the suggestions guys! As far as soaking them in a chemical - they're too far gone for that. Canadian tire says they're a dealer item only (the first stop after i went to after the dealer). As far as fordpartsonline i don't need them anymore cause i checked out the classified ads last night and a guy on here is parting out his car. There now sold to me. Once again - this site has helped me out so much with things.
Posts: 2,586 |
Originally posted by craig: Where could i find licence plate lights (not bulbs) for my car - other than a Ford dealership? (they want $76.53 each). Both lights are so filled with corrosion it's sick. I need these bad. As far as i know they're a dealer only item. Any suggestions other than a wreckers?
Been there done that. I went to a wrecker and bought them for 5 bux each.
works like new now
can it wait till spring/summer?
97 T-Red LX ATX
pre98 CF SVT front,SVT rear/side skirts
FSVT wheels
Custom Front Ford Logo (body Colour)
35% tint all around with sun visor
WP With Metal Impeller?
Elky Grills
CTA Intake
CTA Custom Dual Exhaust
Posts: 186 |
Same thing happened to me. Freaking unbelieveable prices for those little units.
With no local parts cars I came up with a different solution. Use a dremel tool with a soft sanding bit.
I just polished up all the contact points around the connectors on either side of the bulb. It worked like a charm. The lamps returned to full brightness again.
I figured that by the time they corroded again it would be someone else's problem. You could add some vaseline or other preservative to the contacts to prevent further corrosion if you wanted a longer term fix.
Previous owner of a 99 Mystique V6 MTX Black
Current owner of a 2004 Maxima SE MTX Silver
Forsale:
Yakima roof rack. Q-towers, bars, clips, locks. Good condition.
Posts: 186 |
Originally posted by mbb41: Any chance you can soak them in a chemical to get the salt and such out?
Probably a descaler type product. CLR may work, but I've never had luck with it. Soaking in vinegar may be the best soluion. Scrub with a small wire brush to get the majority of the crud off.
Forsale:
Posts: 116 |
well, the guy in the classifieds never got back to me after two more request, so i decided to take the advice of soaking them in cleaner. The auto recyclers also gave me a little attitude, telling me that he's not going to ruin a perfectly good "bumper", just to sell me licence plate lights. I told him that the lights were on the trunk, and he said he'd sell them them to me for $25.00 each. I refused. I ended up rechecking the condition of the lights, and noticed the orange wire on both terminals were completely off. No wonder they didn't work. Duh! I sprayed them with wd40, scrubed them with a toothbrush, then soaked them in dishwater to clean all the corrosion off. Put new bulbs in, stripped the black and orange wires to reveal fresh wire, rewired, and boom, the lights work again. Half an hour total time. Thanks for all the advice guys.
