Page 2 of 2 1 2
#858015 01/31/04 02:57 AM
Originally posted by thejms:
What is the part number for the stock replacement resonator for the magnaflow for the SVT?
I'm running part # 14215. It's virtualy the same size as the stock one on the SVT.
98.5 SVT now gone ... new wheels = 2005 330i
#858016 01/31/04 04:40 AM
And what size is the stock unit?
CSVT Feels Like Heaven Goes Like Hell Profile
#858017 02/01/04 12:09 AM
F
F
Opps, I forgot I wasnt new to these boards so I did a search.
I found some posts that say go with these part #
Resonator-10425
Cat-??
Mufflers-11124
Stazi sent me a pic of the one he sells and it is the 14840. 2.25 inlet, 4"diameter tip, 2.5 internal race core, double wall, 4" tip length, 14" body length. I could not find the 11124 to compare. What is the difference? And I still am unable to find the # for the Cat? Can anyone help. Thanks.
I got the 10425 res and the 14842 mufflers. Don't remember the # for the hi flow cat I got but I got it along with my BAT y-pipe quite a while ago.
Formerly known as Sneaku I MISS MY BABY!!! '00 Blk CSVT #1087/2150 built 12/23/99
#858018 02/01/04 03:39 AM
Tried to contact Stazi but he hasnt replied back. Does anyone else know the part number for the Magnaflow Hi flow cat for the SVT?
Thanks
Justin Schmidt 2000 SVT Tour #1620 of 2150 Born 1/15/2000
#858019 02/01/04 03:46 AM
#14842
2.25" Inlet, 4" Diam. Tip
2.5" Internal Race Core
Single Wall, Angle Cut
4" Tip Length
14" Muffler Body Length
#14840
Double Wall, Straight Cut
4" Tip Length
Not knowing to much on mufflers, but what is the difference between single and double wall? I like the angle cut better. Do you have pics installed?
#858020 02/01/04 04:19 AM
Expect to pay a little more if you're getting the types of muffler above (pricewise and installation wise). There is slight modification required to lower the exhaust system to aim those mufflers straight out. Not very hard I assume, but an exhaust shop will most likely add more for installation.
EDIT: By the way, I assume the single and double wall has to do with the tip. look at the single wall muffler, looks like a pipe cut off. The double wall appears to have a shell type of pipe for "looks" I guess, I would take the slash cut pipe look. Just me though.
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
#858021 03/10/04 10:46 AM
E
E
i have a 98 svt and i'm planning to get the magnaflow mufflers but not sure which are the best for my car. 11124, 14842 or 14840? any opinions?
thanks
eric
Page 2 of 2 1 2
