#857759 01/30/04 07:27 AM
i have a 97 contour zetec engine. i milled the head not long ago because it got warped. runs great when the engine is warm or its warm outside but when its a cold engine and cold outside it runs like crap. it will make a knocking sound until it warms up...the colder it is outside the louder the sound. also the lower the octane gas i use the louder the sound. i know milling the head causes the compression ratio to go up...is there a mod to do to compensate for this?
does it sound like i need to retard or advance the timing?
is there a way to fool the engine into thinking the air temperture is different from what it really is?
any suggestions
Thanks
What does it do when you run premium fuel. I suspect that by milling the head you've upped your compression ratio and few tenths and put yourself into the premium range. The only solution to that is to put a thicker head gasket on to lower the CR.
Sarge43 "00" Tique 2.0L I4 ATX "98" Mustang 3.8L V6 AT The reason there's so much ignorance is that those who have it are so eager to share it.
I milled my head, also due to warpage, and I've gotten along okay by just always using premium gas.
How much did you mill the head ?? Milling 0.023-0.024" will bump the CR from 9.6 to 1 to approximately 10.2 to 1.
Oh, mine got milled a lot more than that. The CR is probably close to 11.
I have a 96 Mystique that was making a hell of a racket, it turned out that the timing belt was hitting the inside of the cover. I had to replace the tensioner and the timing belt (150,000km's). Runs great now. Just take off the cover and start it up, you'll see it. Good Luck.
96 Mystique, 2.0L ATX, tinted windows Head unit: Premier DEH-840MP Front Speakers: Phoenix Gold 5x7's Rear Spreakers: Pioneer 6x8's Sub: 2 12" Pioneer Premier TS-W1240C's Amp: Pioneer GM-X922
Moderated by  Loco4G63
