Posts: 23 |
does anyone know where i could get some different styled lenses for my 98?? maybe somethin like angel eyes?? and for how much?
Posts: 295 |
I think you can get Angel eyes made for the 98+ vehicles. IIRC, they run about $1200. I know there's at least one person on the boards who has them, maybe he'll see this and chime in.
-Jonathan
Jonathan
'96 Contour Zetec MTX
208,XXX miles
Posts: 7,025 |
Originally posted by BlackSativa: I think you can get Angel eyes made for the 98+ vehicles. IIRC, they run about $1200. I know there's at least one person on the boards who has them, maybe he'll see this and chime in.
-Jonathan
that $1200 includes dual projectors iirc....i believe the standard projectors were about $1000 and the angel eyes were a $200 option or something like that. you could make your own for about $20....buy some led's, heat up some clear plastic rods into a circle, dremel some notches out so the light defracts.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 9,442 |
What would you connect them to if you don't have projectors?
Posts: 7,025 |
either make a support bracket on the inside of the housing or what might be easier is once you bend the rod into a circle, bend each end of the rod back 90 degrees so its pointing towards the back of the housing and drill a hole for each end of the rod on the back end of the housing. then epoxy or silicone around the rods once youve stuck them through to prevent any water leaks. then attach your led's to each end of the rod.
Jim Hahn
Posts: 2,779 |
there's a post about angel eyes in general mods. They are on Ebay for $30, just put them in yourself.
