#855840 01/28/04 06:01 PM
X
X
I just replaced my tail light now my head light went out.
is it easy to replace the bulb?
2000 csvt forsale! support our troops
#855841 01/28/04 06:07 PM
E
E
you should be able to do it easily
just pop the hood reach behind the light and remove the bulb.
replace with new bulb
if you cant fit your hand in there, remove the two screws ontop of theheadlight and loosen the lower one.
slide headlight assembly out..replace bulb
#855842 01/28/04 06:08 PM
E
E
that is, if you have a 98+
pre 98 i have no clue if its that easy
#855843 01/28/04 07:04 PM
X
X
thanks for help.
#855844 01/28/04 07:08 PM
I think the pre 98 only has three screws also. father replaced the passanger light after the car was fixed from hitting a deer, just so the headlights would match
#855845 01/28/04 08:31 PM
Z
Z
Nope, the Pre 98's are a pain in the a$$ to remove the whole assembly, they have these 3 clips (not screws). You're much better off just removing the bulb.
To remove the bulb, just reach behind the assembly and you'll feel the bulb harness. Just twist the harness (can't remember which direction, but guessing it would be CCW) and it'll pull out.
- Zack WANTED: T-Red HEATED Side Mirrors FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps 2000 T-Red SVT 1995 LX V6 MTX (RIP)
#855846 01/28/04 08:47 PM
F
Smurfette
Smurfette
F
hehe "lefty loosey"
I agree, pulling the whole assembly out on a pre98 is a pain in the nuts.
#855847 01/28/04 09:24 PM
my bad, never look that close
Moderated by  baco99, frenchblueC2_dup1
