Posts: 13 |
I just replaced my tail light now my head light went out.  is it easy to replace the bulb?
2000 csvt forsale!
support our troops
Posts: 8,445 |
you should be able to do it easily just pop the hood reach behind the light and remove the bulb. replace with new bulb
if you cant fit your hand in there, remove the two screws ontop of theheadlight and loosen the lower one. slide headlight assembly out..replace bulb
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Posts: 8,445 |
that is, if you have a 98+ pre 98 i have no clue if its that easy
Posts: 13 |
2000 csvt forsale!
support our troops
Posts: 6,910 |
Originally posted by ElKy: that is, if you have a 98+ pre 98 i have no clue if its that easy
I think the pre 98 only has three screws also. father replaced the passanger light after the car was fixed from hitting a deer, just so the headlights would match
- 95 Mystique LS - Zetec/5spd
Posts: 2,166 |
Originally posted by brapple: Originally posted by ElKy: that is, if you have a 98+ pre 98 i have no clue if its that easy
Nope, the Pre 98's are a pain in the a$$ to remove the whole assembly, they have these 3 clips (not screws). You're much better off just removing the bulb.
To remove the bulb, just reach behind the assembly and you'll feel the bulb harness. Just twist the harness (can't remember which direction, but guessing it would be CCW) and it'll pull out.
- Zack
WANTED: T-Red HEATED Side Mirrors
FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps
2000 T-Red SVT
1995 LX V6 MTX (RIP)
Smurfette
Smurfette
Posts: 8,770 |
Originally posted by zgendron: (can't remember which direction, but guessing it would be CCW) and it'll pull out.
hehe "lefty loosey"
I agree, pulling the whole assembly out on a pre98 is a pain in the nuts.
Kim
1995 Contour GL
Needs less "needs more"
Posts: 6,910 |
my bad, never look that close
