#855168 01/28/04 12:01 AM
9
9
I had my starter replaced about 4 weeks ago because it was not engaging during turnover. Since then I've had the smell of something burning periodically after turnover. Today, the starter whirled but did not engauge again. Before I talk to the mechanic, I was hoping for some feedback from the Tour pro's in here. Thanks!
98 Contour SE 24V V6 ATX 99 Passat GLX 30V V6 ATX Tiptronic
#855169 01/28/04 04:23 AM
the teeth on the flywheel and or the teeth on the starter are not aligned up and probably the teeth on the flywheel might be chewed up and the teeth on the starter are chewed up and that might be why its not engaging and the motor is just spinning and not turning over( or it could be just the relay on the starter(the selenoid) not moving the starter drive onto the flywheel????), check with the mechanic and see what he says......
