There are 2 plastic lines on top of the intake on 2.5 duratec. One is brake booster. The other ???? I wish I knew what line it plugged into or where it ended up. Can anyone help?
It supplys vacuum for all the other systems that need vacuum to operate. Your AC system uses vacuum to open/close the various doors/flaps.
Bless our servicemen & women overseas. L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
thanks, If anyone knows where to get vac diagrams I could really use that info. I paid a friend to switch over upper and lower intakes to save myself some time. Had a part car for reference, he tore that apart when he took out intake, now ive got a cluster f*$%5 on my hands here. He has some things broken and some things switched around. If anyone can help i am working on it right now and i can use all the info I can get
If he broke the plastic fittings going into the intake manifold, do yourself a favor and pick up some new ones from Ford. Comes with the line if I remember correctly. I did this when I first bought my car becauase they had tape wrapped around the fitting where it was removed previously. Does wonders for a smooth running engine when you don't have any vacuum leaks. I also purchased vacuum assembly where all these vacuum lines come together. Haven't put that on yet, but will when I pull the engine next week.
A vacum diagram should be under the hood of your car.
This is a vacum diagram for a 1996 2.5LT
www.geocities.com/hawk2k1ca/contourpics/vacum.jpg
www.geocities.com/hawk2k1ca/contourpics/ed2.jpg
(I knew this pic would come in handy 1 day)
copy and paste links into a new browser window, otherwise they won't work!
1996 2.5LT V6 Contour ATX My Tour+help/info pics E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
ya good on chongo the link doesnt work
1999 Ford Contour SE Zetec with 137k miles. AIM Name: ContourAlf Yahoo IM: Contour_Freak
heh didnt see the copy the link or it doesnt work heh
