Posts: 105 |
I would like to replace the stock speakers in the door panels, front and rear. Has anyone any recomendation to what brand and size to install. Are the door panels difficult to remove,do I need special tools? I would like to do the job myself to save shop labour. 98.5 se contour. Your comments are appreciated. Thank you.
Posts: 8,142 |
No special tools needed to take the panels off. It's pretty easy.
What is your budget? Do you plan on buying subs? What kind of amp? It's hard to recommend anything without a little more info.
Dave
------------------ 99 SVT Sony ES CDX-C910 Sony Digital EQ/X-over Sony Changer McIntosh MC440M Adire Audio Shiva MB Quart/Vifa seperates
Posts: 610 |
if you want to replace with the same size, pioneer has 4 opions, and alpine has 2 (atleast while supplies last, they are not being made after this year) 6X8 is the size, but with a little modifications you can fit larger speakers keep in mind 2 6X8s can also be put in the back dash let me know how it goes
------------------ 2000 se kkm intake pioneer on the way green interior lights (alot more to come) 1999 se (no mods yet)intake on the way email-jessneric@peoplepc.com yahoo instant messanger-eric_j_linders icq-94866821
capitol ceg/southern maryland 2000 se tropic green kkn intake(will replace with svt soon), green interion lights(replacing with neons), pioneer 4100-no remote, fog light mod, svt exhaust, side markers, badgeless, 9005 instead of 9006(headlights will be replaced soon, pioneer 6x8 3 way(front) and 2 way(rear) need to istall-obx pedels 1999 se steel blue blue headlights and fog lights need to install sony cd headunit email-jessneric@peoplepc.com yahoo im-eric_j_linders aol im-ericsgreen00 msn im-ericsgreen00@altavista.com
Posts: 105 |
Dave
[/B]
The unit I have in my car is all Ford factory am/fm cass.CD stacker in trunk,CD works off fm band.I don't know what the power rating(rms)is, probably not much.It's no power house unit like your probably use-too, sorry Dave.I'm not planning to use subs or install a pre-amp.I have been told that the stock speakers in the door panels are low quality, is this true.The 6x8 speakers after market are much better, right? Will bigger speakers such as 6x9 fit without allot of metal cutting,grinding drilling etc.Will this project be worth the time and cost to accomplish a noticeable gain in sound quality I am a family man and live in Canada,our dollar is not worth a whole lot compared to your US dollar.Whatever you pay, I pay 1.5 times more.It's not your fault,I just want to give you an idea of a budget I like to work in.One last question,the door panels don't have allot of screws? Are the panels held on with clips on the back side. Thank you for all your suggestions.
Posts: 8,142 |
No problem Fuji,
You don't need to spend a lot of money to get good sound. There is a debate which upgrade should be done first, the Head Unit or the speakers. The differences will be very evident with either choice. Since you will probably want as much sound as possible, try to fit some 6x9s. There was a post not long ago about the installation of 6x9s. If I recall, almost no modifications are necessary in the front and some very minor work needed in the rear. When looking for the 6x9s, try to find out specs on the effeciency, which will be written as 90 dB 1w/1m or 90 dB 2.83v/1m. The higher the effeciency, the louder the speaker will be able to play with a given input power.
I would also seriously consider a new HU if at all possible. It'll be worth your while to save up for a little longer. There are a number of good values in the 200-250 dollar range including Blaupunkt, Pioneer, Sony, JVC, etc..
Regarding the doors, they are held on by a combination of securing methods, including screws, plastic clips. They aren't too difficult to remove.
I'll do a little searching on the net to see what I can find for you on some 6x8's or 6x9s. Good Luck.
Dave
Posts: 8,142 |
Ok, I did a little bit of checking around. I think that I would recommend the following 6x9s. 1. Polk EX693A (185.00 canadian at http://www.audioexpress.sk.ca/caraudio_speakers.html ) 2. Kenwood KFC6909 3. JBL DS695 4. Infiniti 6953i 5. Pioneer 69xx Now, the list above are all three way designs that have cheaper 2-way siblings. I think the Polk's would be your best bet as they seem to have the highest sensitivity and also seem to have pretty much the best SQ. I left off Sony because I don't have a lot of info on their new series. I can safely recommend pioneer's but they have a huge variety to choose from. The only knoch is that they won't play at the same level as the first 4 speakers I listed. SQ should be close to most and possibly alittle better for some models. ------------------ 99 SVT Sony ES CDX-C910 Sony Digital EQ/X-over Sony Changer McIntosh MC440M Adire Audio Shiva MB Quart/Vifa seperates
Posts: 105 |
[QUOTE]Originally posted by dnewma04: [B]Ok, I did a little bit of checking around. I think that I would recommend the following 6x9s.
Thank you Dave for all your help.You're a great guy.Very much appreciate all the searching you've done for me. sincerely; fuji.
Posts: 884 |
I have Infinity Kappa 6 X 9 in all four doors. I've had them for 3+ years and love em. Very durable speaker with crisp clear highs. I also have Infinity tweeters in the door vent panels. John
Pioneer Premier DEX-P1R Infinity Kappa 6x9 Infinity 3/4" tweeters Orion Cobalt/Extreme 12" DVC
Posts: 242 |
Detailed instructions on removing the door panels can be found on my ancient and crusty pages. Haven't been updated in ages, but the instructions still work. http://msnhomepages.talkcity.com:/ProtectionFault/modemjunki/C-doors/index.html
2 Red Tours! '96 GL V6 ATX - the wifes ride '98 SVT with both options - my toy! K&N / Glove Box Light / an dats it!
Posts: 105 |
Thanks jc-aimhigher for the 6x9 acid test review. Thankyou 2 redtours for the detail drawings from your website,your pictures are worth a thousands words.Good stuff!! Many thanks guys; fuji.
