Posts: 30 |
Hello Again, The 2.0 in my daughter's car has finally given up completely. We pulled the head off and found that the #2 Piston was broke in two pieces. It looks like rebuilding may not be a good option. Not really sure where all the pieces went. I am wondering if a newer model Zetec motor like the one in the Focus, etc. would be compatible with the 95 GL? Need to get her back on the road soon.
Greg
"I Believe In Ford"
02 Expedition EB
95 Contour GL
91 Mustang GT
87 Mustang GT
66 Mustang Coupe w/5.0/T5
Posts: 2,725 |
Originally posted by Raven62: Hello Again, The 2.0 in my daughter's car has finally given up completely. We pulled the head off and found that the #2 Piston was broke in two pieces. It looks like rebuilding may not be a good option. Not really sure where all the pieces went. I am wondering if a newer model Zetec motor like the one in the Focus, etc. would be compatible with the 95 GL? Need to get her back on the road soon.
Greg
Focus one is about the same size, I have seem then before and they appear to be about the same size. However if they arent you will need to get new mounts to support it. Also plan on getting a new wiring harness, and a PCM, and most likely a few other things.
Why dont you just rent or buy a engine hoist, and a Haynes manual and the parts you need and fix your engine, it is cheaper by a long shot than swapping a newer engine for an older one.
Posts: 30 |
I don't have alot of faith in this motor. It has been overheated twice now with devastating results! Warped the head and blew the head gasket last time. This time some thing except the #2 piston problem too. Figure I should cut my losses. I found several motors on the internet but only a couple for mystique/contours. The rest are Zetecs but for the other cars.
Thanks for the reply. I haven't completely ruled out the rebuild yet.
Greg
"I Believe In Ford"
02 Expedition EB
95 Contour GL
91 Mustang GT
87 Mustang GT
Posts: 2,091 |
Focus Zetec is VERY different...been there, tried that...move on. Buy a contour motor.
Posts: 495 |
Have you tried here? http://car-part.com/ Huge database of used parts including whole engines.
2000 Rio Red I4 Cougar
200whp & 210wtq at 9psi
254whp & 276wtq with NX 35shot
WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
Posts: 30 |
Thanks for the advice about the Focus Motors. I will drop that thought from my mind.
Seawulf... Great site!!! Thanks I can even find places here in NC.
Greg
"I Believe In Ford"
02 Expedition EB
95 Contour GL
91 Mustang GT
87 Mustang GT
Posts: 1,505 |
i use to have a 97 contour GL sport Zetec engine i have a 99 now zetev VCT the only thing i see diffrent is the oil filter is smaller than the older zetec engine i beleive it can work
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
Posts: 185 |
Isn't the Escort ZX2 motor the same zetec?
God graced us with intelligence, let's use it.
