#848819 01/21/04 03:42 AM
N
NJE96SE Offline OP
N
I think I have this right, but I'd like some reassurance.
A Duratec V6 has an oxygen sensor in each manifold before the pre-cat and one after the pre-cats but before the main cat. Is that all, or is there a fourth one?
I have a CEL so I went to Autozone. The guy told me it was the second sensor in bank 1 that was going out. Is that the sensor in the y-pipe? Is bank 1 the manifold between the engine and the firewall? BTW, this CEL came on 10 minutes after installing a new y-pipe.
Thanks for your help.
06 Mustang GT - stock 96 SE V6 5spd Midnight Red - 15.9 @ 86.8 150K miles Mods: Bilstein struts, H&R springs, Borla Cat-Back, Brullen y-pipe, Gutted Precats, SVT UIM+LIM+TB, K&N FIPK, , DMD, Magnecor KV85
Four sensors - one before and one after EACH pre-cat.
Bank 1 is the firewall side.
Do not rely on the AZ drone's interpretation of the codes. Post the codes here to a second opinion before buying or replacing any parts.
Maybe a sensor did not get plugged in completely. Worth a check.
Steve
Also, O2 sensors are notoriously fragile when not in their native environment in the exhaust stream. If you banged it about just a bit, it may have been damaged.
yes, bank 1 sensor 2 IS the sensor in the y pipe. There are 2 before the precats in the manifolds, then 2 lowers( 1 in the y pipe and the other very visible after the precats in the front exhaust manifold).
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
N
NJE96SE Offline OP
N
I wonder if this is the case here. I had it installed at a shop so I do not know if the service guy dropped it or something. I will check to see that it is plugged in tightly and if it is then I guess I will try replacing it.
Thanks to all for the comments and help.
BTW, JonnySVT did you get things straightened out with Brullen about your y-pipe?
