Posts: 23 |
Question for the experts: I just brought a tour with 45k miles, but i don't now which kind of oil was used in the past. What kind of risk implicate change to Mobil 1? Any kind of leak or something else? Thanks
Posts: 851 |
I switched my old 'tour to Mobil 1 at 90,000 miles. It had been using conventional prior to that. No leaks or problems from changing over.
Posts: 3,867 |
Originally posted by gabocar: Question for the experts: I just brought a tour with 45k miles, but i don't now which kind of oil was used in the past. What kind of risk implicate change to Mobil 1? Any kind of leak or something else? Thanks
None.
I switched at 50.
There used to be seal problems back in the early 70's, but those were quickly resolved.
Only other possibility is if you have a potential leak that is sealed with sludge. When the synth cleans off the sludge, your potential leak becomes real. First off, I don't believe your going in condition is one you really want to live with, and secondly, I don't think it's very likely with a 45k engine.
Function before fashion.
'96 Contour SE
Posts: 9,196 |
Before owning my CSVT I had (3) Buicks that I bought used, an 87 GN, 89 LeSabre T-type and a 93 Park Avenue Ultra. They all had 80K+ miles on them and I switched over to Mobil 1 w/o any problems  During the winter monthes you might want to get 0w30 Mobil 1 to aid in start up, just to help things get warmed up on those cold winter mornings
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
Posts: 328 |
Originally posted by brianl703: I switched my old 'tour to Mobil 1 at 90,000 miles. It had been using conventional prior to that. No leaks or problems from changing over.
Me, too.
- Jim
Our yardbirds:
Belvedere, our '96 Jeep Cherokee, 4.0L ATX, 85,000 and going strong
Spencer, our '03 Chrysler PT Crusier, 2.4L ATX, 28,000 and just getting started
Posts: 1,616 |
I changed my 1991 BMW 535i over to Mobil-1 at 141,000 miles. Not a single problem or leak.
Just do it!
