I would like to replace the clutch in my CSVT, but am puzzled about these special couplings right between the intake manifold and the LF strut tower. The manual says to remove them with these special tools:
Disconnect Tool, Spring-Lock Coupling
310-D004 (23-039)
310-D005 (23-039)
Also, on the fuel supply side, it looks like the owner before me tried to just take the hose off from the coupling and was unsuccessful. The fuel lines are of a construction I haven't seen before. It almost looks like shrink tubing surrounded by a standard 3/8" fuel line. I also wanted to know if this small, thin line alone will be able to withstand the pressure of the fuel system. I have made a replacement hose to put over it, and secured it with 4 hose clamps tightened just enough to try to relieve some of the stress on the line. If anyone has any pointers, let me know! If anyone needs pictures for a better idea, I will gladly send you some. Really appreciate it!
Sean
