#69967 10/06/00 06:45 AM
Scoriox Offline OP
well lets see here.. how can i explain this... recently bought and had installed a JVC el kameleon.... worked fine with factory speakers... i then bought 4 infinity kappa 5 x 7's and all of them work EXCEPT in the left rear... when i connect it its makes this buzzing/beeping/rat tat tat noise.... i cant really explain it but it does bother me only having 3 speakers.... any clues? could this be that stupid walkman amp behind the glovebox (there is an adapter from the HU to it and it has gain settings, but none work) if u need more details ill try to explain..
1998 Black SVT Contour.
No Mods yet.
~Matt
#69968 10/06/00 01:32 PM
I would check all the connections from the HU to the speakers...If they are all ok, then try connecting a different speaker to the door that is not working. This should eliminate the possibility that the speaker is bad.
Are you using the factory amp? If you are, bypass it.
#69969 10/07/00 03:34 AM
V
V
not an expert, but from what i hear is if you buy an aftermarket HU, its internal amp is probably better than the 14watts the crap stock amp puts out. Try bypassing the amp...how many watts does your JVC put out?
1998 E0 Ford Contour SVT
Built on 8/19/97 -- #3101/6535
Silver Frost/Midnight Blue
* New Cupholders * CEG sticker =) * 9005 Philips BlueVisions * Sound System: Kenwood eXcelon KDC-X617 HU, RFosgate fnq514 components, RFosgate 6x9 3ways, RFosgate 12" sub, MTX 5ch/800w amp, 1 Farad Cap * Removed Ford emblems * Fogs w/parking lights and aimed up * Brushed Aluminum Style Grills all around * 205/55/ZR16 Bridgestone Potenza RE730's * Removed Headliner * Visit MY SVT website (UNDER CONSTRUCTION)*
#69970 10/07/00 03:38 AM
My stock stereo does the same thing
go figure
A. Van
95 Eagle Talon TSI AWD
98 Contour SVT ( For Sale )
SVT/SHO
Society
#69971 10/08/00 03:36 PM
Scoriox Offline OP
its 45 x 4...... and i tried all the things that dnewma04 said to no avail. nobody in my region seems to sell an amp-bypass connector (bestbuys answer was to give me the installation kit for the football shaped taurus)
guess im gonna hafta go crutchfield..
~Matt
#69972 10/12/00 09:45 AM
Anonymous
Unregistered
Anonymous
Unregistered
I had just bought a new alpine swing series deck about a month ago, same problem. I ended up sending it back on warranty. If your deck isn't working correctly then it should be replaced immediately. JVC is usually reliable stuff so there shouldn't be any problem replacing it.
#69973 10/12/00 01:45 PM
all my speakers worked on my HU(stock and aftermarket) when i put it in. after installing my system (me and my bro) my front speakers arent loud enough till i hit a certain volume on the HU. So maybe ya got the same thing i do where its on and its workin its just not as loud as the other speakers and they are being overpowered.
-afr0
it doesnt bother me cuz that only happens at low volumes 1-8
-afr0
Moderated by  dnewma04_dup1
