Posts: 170 |
What is everyones opinion of this amp! Detailed specs and real world experience would be great too!
------------------ 99 SVT K+N 35% 3M tint on all 5 windows Rear valance painted silver Special lightweight tires! "Anything is legal as long as you don't get caught"
99 SVT K+N 4/99-35% 3M tint on all 5 windows 6/99-Rear valance painted silver 10/00-Painted all the grilles silver as well! 10/00-D & T short shifter 225/45/16 Kuhmo Ecsta 712s 3/01-Red Ford Emblems with Black flames
The SVT is like....numbered and stuff-#1079/2760
Posts: 94 |
i have that amp and it kicks the #$$# outta my 2 infinity perfect with the gain alllll the way down and the boost is about at 40hz ;] wierd to wire it up cuz it has 2 8-gauge power inputs. It takes high volts too 9 rms around.
i personally love the amp it doesnt drain my car too much with the cap and it runs cool as hell.
-afr0
pioneer headunit, 4 6x8 pioneer compression horns, premier 4 channel, PLD1 line driver, 2 12" infinity perfects in custom boxes, 1 farad cap, a MTX crossover (temp. until i can get the money for an audiocontrol) infinity beta digital 300 runnin 9 volts into it, bridged mono wired in parallel. ;]
"dont front cuz i know you were an ice fan"-vanilla ice
Posts: 170 |
Yeah it seems to be two mono amps in one chassis! I was just curious because I bought one because of the great price, but haven't installed it into anything. See ya, Travis Originally posted by loudest_contour: i have that amp and it kicks the #$$# outta my 2 infinity perfect with the gain alllll the way down and the boost is about at 40hz ;] wierd to wire it up cuz it has 2 8-gauge power inputs. It takes high volts too 9 rms around.
-afr0
Posts: 8,142 |
I've heard good stuff about the new Infinity digital amps. They had a lot of problems a few years back that they seem to have solved. Class-D amps in general are much more effecient then Class A/B amps. That leads to them running cool as "loudest contour" pointed out. I don't think you will have any regrets if you buy one.
Posts: 94 |
agreed -=D team it up with a line driver and your set unless ya got a HU wit a high voltage output like 6.5+. i like the adjustable boost level anywhere from 20-80 is a pretty cool feature. make sure all the dials work and they dont go past the extremes cuz the first one i had did that and it just fried itself when i put power to it... the second is the one hooked up now and for 400 bucks its nice power.. wierd config. the mmats amp should dominate it (or so i hope).
-afr0
no sig
happy BOOOOMIN
