#844767 01/16/04 06:49 AM
sacd3 Offline OP
Were is the best location for the amp ground wire?
#844768 01/16/04 09:20 PM
I have mine under the seat cushion....that is what my local shop suggested, but i'm sure other people use other places here.
#844769 01/16/04 10:10 PM
sacd3 Offline OP
were is your amp at?
#844770 01/16/04 10:13 PM
sacd3 Offline OP
right now I have my ground wire on one of the bolts for the brake light but my amp is not switching on at all, and this is the only thing I can think of, i checked all my fuses and they are ok and the amp worked fine when installed in my other car. so I wonder if any one else has had a simular problem with this ground location
#844771 01/17/04 01:09 AM
Is the grounding point free from paint? Did you check the stereo signal wire?
Former owner: 1999 Contour SE Sport Current: 2000 Eclipse GT There are three ways to do things: the right way, the wrong way, and the Max Power way! Isn't that just the wrong way? Yeah, but faster!
#844772 01/18/04 07:33 AM
sacd3 Offline OP
it looks to me like it is free of paint. the more and more i think about i think that it is more than likely the remote wire
#844773 01/18/04 07:48 PM
sacd3 Offline OP
nope wasnt the remote wire, i didnt remove any paint from the grounding point so im sure thats whats doing it. please if anyone knows of an easy place to ground, or the most effective way to remove paint back there let me know
#844774 01/19/04 04:16 AM
I used the power Antenna mount on my SVT (pass side of trunk) Also get a digital volt/mulitmeter. You can find out why your amp is not turning on in a matter of minutes instead of guessing. Makes for a very handy tool when working on your car.
Previous Owner of 00 SVT Contour #1077/2150 95 Contour SE '01 3L
#844775 01/21/04 01:10 PM
sacd3 Offline OP
ahhhh the antenna mount works great! thanx
Moderated by  dnewma04_dup1
