checked all the bolts that mount the housing and for the thermostat and they are tight.
the upper radiator hose has been replaced as well as the short tappered one below it. the one off the back was replaced where it runs after the metal pipe to the heat core, the short little bent section wasn't. all the connections appear dry and the changes were last june at the latest.
I think it has something to do with the cold, it started after the car was run rather quickly 4 times one day in the very cold, about 10 degrees, to and from work, not even 5 minutes, and to move the car to get another out of the driveway and back. the first leak happenned over night, or that is how long the leak took to leak enought to run over the bell housing and trans and to spill to the ground
still cann't see any physical leaks other then the bottom sensor in the housing is very damp
edit: forgot to mention that we reused the clamps on the new hoses, the housing has never been removed by us, jus the thermostat, so we are thinking the clamps overnight are leting coolant out
