First thing you should do is put a volt meter on your battery with the car running and see what voltage your getting...should be about 14.5 volts, then turn on your defroster and wipers...should still be close to 14.0 volts.
If its not...your alternator is gone, also check your battery voltage with the car off...should be 12.8...or so.
