Looking for opinions on this.
I currently run stock springs with Koni's and the Aussiebar. I am very pleased with the handling of the setup, however, I wonder if stiffer rear springs with the stock swaybar would be a better setup. Here's why.
*You could attain the same roll stiffess as with the aussiebar with stiffer rear springs, maintaining the overall neutral handling the Aussiebar delivers.
*The stiffer springs would help minimize weight transfer rearward while accelerating out of corners, minimizing wheelspin and understeer, allowing us to put the power down sooner on corner exit.
*By using the stock swaybar, the clunking and broken bracket issues that some experience with the Aussiebar would be a non-issue.
*The stiffer springs would help the car handle load. For example, a heavy load in the trunk or rear seat pasengers. The stock setup sags considerably.
*All this would come at a penalty of a stiffer ride in the rear.
Now a few questions...
-Does anyone know of stiffer springs for the rear that maintain the stock ride height, or are adjustable ride height coil overs the only option? (could adjust corner weights if necessary.)
-What are the stock spring rates? I need this to estimate the spring rate necessary to maintain the roll stiffness of my current setup(to maintain neutral handling.)
Anybody have any thoughts or opinions on this????
