X
xdouble Offline OP
X
Hey guys, I want to put my Kenwood cd player from my old car into the contour. Crutchfield gave me these 2 pronged things that you are supposed to be able to stick in to the sides of the stock radio and pull it out. They say to apply outward pressure (which I've tried) and pull. Problem is, nothing happens. Any hints would be appreciated, otherwise I guess I'll have to remove the molding around the stereo to get at it.
Thanks,
~Matt
2000 - SVT - Toreador
Matt
2000 SVT Toreador
#1210 of 2150
Removing the moulding won't help you. The tools they gave you should click in. Then when you push out, it should slide right out. Try pulling harder or pushing the tools further in.
Louis Wang
Sugar Land, TX
1998 Black E0 #3826
http://web.wtez.net/tw57472
-Louis
1998 Black E0 #3826, lightly modded
If you start to get pissed while removing the stock HU, walk away for five minutes! You don't want to rip out the molding.
Reggie Wallace
'98.5 SVT (E1) - Silver Frost
#5450 out of 6135, born-on date: 4/1/1998
...I wouldn't want to bore you with my mod list :-)
Anonymous
Unregistered
Anonymous
Unregistered
I had a hard time to, when I did do it right, pushing the tools outwards, it came right out.
Thanks,
~Matt
put the tool in and bend outway like this
<---: hu :--->
then pull out simply pulling out doesnt get it out and the tools come flyout and start to strip because the clips are still in the same place minor detail im sure everyone forgot i take it out everytime i go to get my car serviced cuz they said my HU is the cause of my hose problem
let me know if it works -=)
-afr0
pioneer headunit, 4 6x8 pioneer compression horns, premier 4 channel, PLD1 line driver, 2 12" infinity perfects in custom boxes, 1 farad cap, a MTX crossover (temp. until i can get the money for an audiocontrol) infinity beta digital 300 runnin 9 volts into it, bridged mono wired in parallel. ;]
"dont front cuz i know you were an ice fan"-vanilla ice
Moderated by  dnewma04_dup1
