I'm trying to install a Kenwood KDC-515S head unit in my 98 Contour GL. I bought the wiring harness from circuit city, then spliced that harness and the one from the head unit together with directions from install Doctor (www.installdr.com). I went to turn it on but nothing. So I unplugged everything and plugged the OLD STOCK radio in and now it won't even turn on. I do not have premium sound. I checked the fuse under the dash and it was fine (seems like 7.5 is small though?). I tested the +12 volt ignition wire in the stock harness and it is getting power, I also hooked up the new harness that I made (circuit city + one from new radio) and tested the ignition wire on that end with no problems. I'm out of ideas, I tried the reset button on the new head unit, no luck. What could it be that even the old radio isn't working now?!?!?!
Please help, I'm going nuts!
