Have the gas cap tested to insure it's sealing correctly. Around here you can get it done at most tire stores. If the gasket is worn or cracked, you can hear these noises as the gas cap is vented and the defective gasket affects the venting. Oddly enough, a bad gas cap can make the CEL come on as well. An improperly vented fuel system can also cause bad gas mileage. Just a thought and something that's easy to check.
'99 Sport TropicGreen,Duratec, SVT exhaust, Brembo rotors, Ceramic pads, K&N filters(oil & air), Alpine CDM7874, Polk DB570 speakers front and rear. Fog light mod. 50% Formula One tint.
