#839737 01/10/04 08:04 PM
Y
Y
give ma a link to some sort of instructions on changing out the Transmission on my 'tour.
Specs:
1995 Ford Contour
1999 2.5L Duratec
I am about to buy the transmission and clutch, and I *know* how much of a PITA it is to change it, so please no useless posts about that. I just need links on instructions to change it out. If none available, then I will go 'buy the book' so to speak. Thanx.
Jeremy AKA Jai **'95 SE Contour / Midnight Purple (R.I.P)** -------------------------------------------- Hopefully soon to own a candy red 1992 Caddilac STS ~ w00t w00t!
#839738 01/10/04 09:50 PM
I recomend buying a shop manual cd from the classified section.
"...first he's gonna s*!t, then he's gonna kill us." 1999 Contour SVT Retrojunk.com
#839739 01/11/04 04:59 AM
I also recommend a manual.
In the most basic terms, you support the engine from above then you remove the subframe from below to gain access to the transmission.
#839740 01/11/04 07:41 AM
the "easiest" way would be to drop the subframe, that is, if you have access to a lift
if you dont will have to pull it from the top
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
#839741 01/11/04 07:49 AM
Buy the factory service CD's
'nuff said!
#839742 01/12/04 12:57 AM
Y
Y
I just went and replaced the bettery tonight. Put it in, cranked it up, and it cranked up no problem. Turned it off, after about two minutes, went to crack it immediately afterward, and it's dead..... That's another 300$ to add to the 1300$ transmission change. 1600$ might as well be a million for me. I'm 17... I have a part time job, and basically no family. I can't afford that. In the 'as-is' state it's in, the best offer I have gotten for the damn thing is 400$.. I'm about to just sell it. It's a very depressing night, and I can't stand the thought of getting rid of it. My paychecks would take years to get the amount needed. I hate having it sitting there, and for someone my age, having no car is no BUENO. I can't believe what a [censored] night this has been. Thank you all for your help, and be grateful, that you own a car, that if it needs maintenance, you can somewhat afford it.
Good night everyone.
-Jai
