#839620 01/10/04 04:52 PM
It was on my way back from Miami. I gave turn signal when I was chaning lane on the turnpike. Normaly it makes a klick klack noise while blinking. But then it klick klacked like crazy fast, I thought the dashboard is gonna explode. And if this wouldn't had scared me up enough smoke came out just behind the steering wheel for a couple of minutes. But after a while the skoke ended, and after half a hour the noisegot away too, only coming back from time to time or always when I'm giving a turnsignal?
What's goin' on in my Contour??
Murat from Germany previous automobiles: Citroen CX 2.5 GTI Opel Kadett 1.4 1996 FORD CONTOUR GL/SPORT 2.0l 16V DOHC
#839621 01/10/04 05:25 PM
well the fast clicking is a way for the car to tell you that you have a light out. check out your tail lights and brake lights for that one...as for the smoke, I dunno what to tell you...
1995 SE 2.5L V6/MTX 187k
#839622 01/10/04 05:30 PM
I have/had a similar problem, although i couldn't actually see the smoke. Still dont know why mine did this. Crazy Turn Signal Thread
#839623 01/10/04 06:05 PM
Al lighs are OK, this an't be the reason. Also the fast klicking comes from time to time and goes away again. Sometimes the klicking is even very slow.
#839624 01/10/04 06:51 PM
Very likely you have a failing turn signal switch. I had similar symptoms (without the smoke) as mine was failing.
#839625 01/11/04 03:12 AM
I don't think that the turn signal is wrong, it works normal. And it wouldn't explain the smoke, which is the main issue.
#839626 01/11/04 04:48 AM
I suspect that the smoke came from the switch. There have been many posts about how things behave as the switch fails that you can learn about if you do a search. Your problem, less the smoke, is consistant with them.
#839627 01/11/04 03:11 PM
Could also be a relay thats overloaded and clicking...possibly a short in some wiring . If you smell smoke then you have a serious problem...likely wiring somewhere. Do a good inspection of your wiring, and check the wiring under the hood closest to the firewall...maybe the smell of came into the car from the engine compartment. But in any case...something is burning, so do some carefull inspection looking for melted insulation ect.
#839628 01/12/04 12:54 AM
I suspect faulty relay...
#839629 01/12/04 01:29 AM
Smoke maybe bad flasher, I believe that is inside the steering colum... or a wire shorted out in there, and made a light not work, then flasher goes faster....
Former owner of a 1995 Ford Contour GL w/ 2.0L ATX Proud owner of a 2005 Ford Taurus SE 3.0L V6 Vulcan --Looking for Commodore stuff (Drives, Units, Amiga, games, etc)If anyone has any of this laying around and wants it gone, lemme know --
