Posts: 103 |
i just installed a set of Cerwin Vega stealth 10's and had to run the power wire through the fender and door jamb.....this sucks and would like to know if there is a simple way to route the wire before i start drilling the firewall.....any help, thanks
------------------ 95 contour lx, duratec, MTX, mods postponed while i kill the bugs
95 contour lx, duratec, MTX, mods postponed while i kill the bugs, if you have AOL put me on your buddy list if ya feel like it and I'M anytime
Posts: 3,598 |
Check the lower righthand corner of this pic: You can see my power wires going through the grommet. That is a factory hole in the firewall. Pull of the retaining clip that is to the upper left of that hole and pull the insulation forward and you'll see it. Take out the grommet and then use a long, thin screwdriver or something to feel directly behind it about 4". That's the other side of the firewall. There's a matching grommet on the inside of the car. Just push it until it pokes through into the passenger compartment. Look up about 6" above the passenger compartment fuse box from the driver's side footwell. You should be able to see it. Just poke holes in the grommets and run your wire.
\'94 Cobra #4963/5009, black on black, not quite stock Formerly owned a black '00 SVT, #1972 Join the SVTOA! RIP - Ray "Old Fart Emeritus" McNairy
Posts: 117 |
you can also go through the stering column boot, it is made of plastic at the bottom covered in rubber, drill thru that and route as normal.. just make sure your at the bottom of the boot.
Posts: 103 |
thanks all, excellent suggestions. ill let ya'll know what i do.
