Posts: 19 |
I just got this repo car wich I found to be a really nice car.The problem is that when I brake a little hard the front of the car tends to pull to the right. Front rotors shaved Front new pads Rear drums shaved Rear drum cylinders and shoes changed new Full bleeding of system. The problem still there, just less abrubt. 1999 contour, no abs. ANY HELP??
Posts: 2,382 |
"Fear is the little death."
Muadib.
Posts: 19 |
I considered that probability but didn't work it out since both calipers needed to be pushed back to change the pads. I think I'm gonna take your adv. and take a closer look. thanks !!!
Posts: 2,725 |
Originally posted by wilfredom: I just got this repo car wich I found to be a really nice car.The problem is that when I brake a little hard the front of the car tends to pull to the right. Front rotors shaved Front new pads Rear drums shaved Rear drum cylinders and shoes changed new Full bleeding of system. The problem still there, just less abrubt. 1999 contour, no abs. ANY HELP??
What the guy said your caliper is bad.
See the capiler pads are not evenly each away from the rotor. One is closer than the other so one pad has more force than the other, because the other is touching as much.
Dont drive to much or you will be replacing the pads.
Posts: 3,395 |
Did you bleed the brakes? That might help
Posts: 1,660 |
Make sure the tires are the same brand, model and size, and that they're inflated equally. A long shot, but a 2psi difference across the front tires really caused havoc with my old Miata's braking and acceleration.
Scott
Troll! '99 BMW 328i
Posts: 1,228 |
Might want to have an wheel alignment done too. Inspect suspension bushings. A bad bushing (front control arm, rear) might shift on braking and cause a pull.
BEFORE: '99 Contour SE Sport
Duratec ATX Spruce Green
Posts: 19 |
Left control arm, rear bushing dead gone... Changed the arm and the problem was no more... Thanks to every one who responded...
