#69407 08/31/00 04:36 PM
mikey Offline OP
General question for all you that know about "audio stuff", (as you can tell...I'm not one of you)!
When they say an amp is "bridgable", what does that mean? What does it do for you?
Thanks ahead of time!
mikey
99 SVT (Black) # 2642 of 2760
Mirko Racing Intake \K&N Filter (RU 3130)
BAT Air Inlet Pipe
HD Motor Mount Inserts \Front - Rear Sway Bar Bushings
BAT 22mm (Rear) Sway Bar, Bat Springs \ Koni Sport Struts
Performance Fords - Spherical Rod End Links (Rear)
Performance Fords - Street Link
SHO Shop Strut Tower Braces (Front and Back)
SHO Shop Body Sub Frame Connectors
Aeroquip Stainless Steel Brake lines (Front/Back)
Sho Shop "Y' Pipe
Magnecor Wires \ Bosch +4 plugs
Ford Dual Mass Crank Damper
Pillar Guage Pod
Perma-Cool Remote Oil filter Mount
Summit Racing Polished Almn Battery Relocation Kit
MSDS Headers (not installed)
B&M Short Shifter
Sparco Pedals (4 pedal set)
(I think I got 'em all)...someone sell me something else!!
#69408 08/31/00 05:51 PM
Bridgeable means that an amp has versatility. Lets say that you car has 4 door speakers and nothing else. Then you will need a 4 channel amp. Lets say that you then put 2 subwoofers into the back of the car. You will then need either a 2 channel amp, or a 4 channel amp that can be bridged down to two channels. (or other examples) If an amp is 100 watts by 4 channels, and it is bridged to two channels, you are in effect doubling the power, but losing half as many channels (200 watts by 2 channels). This is a rough estimate, as it does not exactly alwats double the power. This was a terrible explanation, but hopefully you get something out of it.
AJ M.
Mmies8646@rowan.edu
take away capital M above for email
http://elvis.rowan.edu/mieskola
MODS:
Cerwin-Vega Door Speakers
JVC CD Head Unit
JBL GTQ220 Amplifier
Sony 2540 Amplifier
Kenwood 8" Dual Voice Coil Sunwoofer
JL Audio 8W3 Dual Voice Coil Subwoofer
1999 Ford Contour LX ATX
Color: Black
Engine: 2.0 Liter Zetec
MODS:
Kenwood CD Head Unit
Alpine V12 Amplifier
Polk Audio 12" Subwoofer
16x7 Motegi MR12's in Silver
205/55/16 Goodyear Eagle RS-A's
Soon:
SVT Body Kit
Forced Induction
#69409 08/31/00 06:50 PM
in short, you can turn any number of channels of power into a smaller number of channels with more power per channel without damaging the amp.
the relationship doesn't always have to be 4-to-2. it could also be 2-to-1 or 4-to-1 depending on the features of the amp. and like jerseycat said, in this case if you have an amp rated at 100 watts per channel, and you bridge all four channels into 1, you'll have 400 watts total to feed 1 speaker.
http://www.crutchfield.com has more info and FAQ's on common audio terminology.
hope this helps!
1995 GL Zetec MTX
KKM Intake
Superchip (yay!)
ASP Underdrive Pulley (to be installed soon)
AR 16x7 w/ Dunlop W-10 (205.50.16)
Viper 500+ Alarm
Sounds by: Pioneer CD/Polk dB/MTX Subs/Alpine Amp
Richbrook Shift Knob
"Recontented" Factory Instrument Cluster w/Tachometer (need to adjust mileage)
"Cheapo" Foggies
98+ Sail Panels (to be installed...maybe)
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t
1974.5 MG B GT
Moderated by  dnewma04_dup1
