Posts: 7 |
Just a note that cleaning the IAC valve cures moose in 2000 Duratecs as well. Thanks.
P.M. Summer -- simul justus et peccator
2000 SVTour Silver Frost 374/2150 -- #9669 of 11445 total run
Cars I want:
Lotus Elan S2, Austin Healy Sprite Mk I, my old BMW 2002 back.
http://home.swbell.net/pmsummer/PMSSVT2.jpg
Posts: 1,341 |
Posts: 1,145 |
take it off and spray it with some carb cleaner or tb cleaner
98.5 Black SE ATX
Posts: 235 |
If it is under warranty take it to Ford and they will replace it. I have done so twice.
2000 Black CSVT
MagnaFlow resonator, SHO/K&N cold air intake
Posts: 715 |
Is this the IAC? The silver round part? Is it easy to clean and not a britle piece to take off? Thanks,
Brian W. -------------------- Black 1998 SE 5 speed - TOTALLED
Posts: 7,117 |
That is the hose that goes to the IAC. Look at the picture again. Just past the flying saucer lookin' EGR valve you will see a bolt in the Upper Intake Manifold. That is the upper bolt that holds the IAC valve in place. You can see the silver cylinder with the wires plugged into it right above where the guy is pointing, that is the body of the IAC.
Posts: 715 |
Excellent, Thanks Any special care that needs to be taken when cleaning it? Originally posted by TourDeForce: That is the hose that goes to the IAC. Look at the picture again. Just past the flying saucer lookin' EGR valve you will see a bolt in the Upper Intake Manifold. That is the upper bolt that holds the IAC valve in place. You can see the silver cylinder with the wires plugged into it right above where the guy is pointing, that is the body of the IAC.
Posts: 7,117 |
When I cleaned mine 6 months ago, I used TB cleaner. After that was dry, I sprayed some silicone lubricant into it & let that dry. Everything is working just fine.
You will want to have a gasket handy to replace the old one which will likely come off in pieces - might cost you $2. While you're at it, I STRONGLY recommend you perform a TB cleaning if you have not already done that. Pretty easy & will take an extra hour or so. You might also need a TB gasket if you clean the TB, $4 from the dealer.
Enjoy!
