Posts: 195 |
What are secondaries? Thanks, John
1998 ContourLX V6 ATX
Cats Gutted+MIL Eliminators
Grandma gave me the finger
Posts: 1,145 |
the second set of valves/intake system for the V6 engine
98.5 Black SE ATX
Posts: 195 |
Thx Gearhead. So there are 12 of them? I've read posts about them not opening. How can you tell. Thanks, John
Posts: 1,145 |
yup 12 of them if you look at the intake manifold IIRC its the longer runners
if your car is really slow above 4000rpm then they prob are not opening
98.5 Black SE ATX
Posts: 1,228 |
Originally posted by gearhead98: yup 12 of them if you look at the intake manifold IIRC its the longer runners
Actually there are 6 secondaries, 6 primaries. 12 is the total intake valves/intake runners.
BEFORE: '99 Contour SE Sport
Duratec ATX Spruce Green
Posts: 2,382 |
Originally posted by jmatzick: What are secondaries? Thanks, John
There are no lame ?'s in CEG land!
You can tell if your secondaries are opening by looking at the drivers side of the engine, underneath the air tube assembly, by the throttle body (under that). If you have the engine running, and you rev it above 3800 RPM, and with a flashlight looking in that area you'll see a little metal linkage moving forwards and back. That's the linkage that opens the secondaries.
Older Tours often have the plastic clips, that hold the linkage on both ends, break off and the linkage doesn't open the secondaries anymore after that.
Cheap part from the dealer too, easy to fix as well.
Take a look and see for yourself
"Fear is the little death."
Muadib.
Posts: 328 |
And there are never any lame answers either!
- Jim
Our yardbirds:
Belvedere, our '96 Jeep Cherokee, 4.0L ATX, 85,000 and going strong
Spencer, our '03 Chrysler PT Crusier, 2.4L ATX, 28,000 and just getting started
Posts: 195 |
Posts: 7,117 |
Originally posted by Contouraholic: Originally posted by gearhead98: yup 12 of them if you look at the intake manifold IIRC its the longer runners
WOW!! Makes me feel like I'm drivin' a Jag! Actually, I kinda am driving a Jag!
Posts: 2,426 |
OK, how about this one. What is a dual honed intake manifold and how will it help me? I got an optimized TB from BNoon and he mentioned it. I asked him but I figure this way, I'll get a bunch of answers and opinions. Thanks guys.
