Posts: 40 |
Hi all
I have a 1997 Zetec Contour and have been having misfiring problems. I've replaced the spark plugs and wires, didn't help and have now purchased a replacement KEM ignition coilpack.
The problem is that I am not sure how to connect up the spark plug wires in order to get the correct timing.
The new coilpack came with instructions that say 4 cylinder application EARLY and 4 cylinder application LATE with cylinder 2 and 3 swapped, which one should I choose LATE or EARLY??
If I play around with it and hook it up wrong could I mess something up?
Thank you!
Tom
Posts: 21,653 |
Should connect about the same as orginial coil. Just compare. It shouldn't mess anything up, MAYBE fry a plug, and the car possibly won't start.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
CEG road warrior
CEG road warrior
Posts: 17,248 |
You would be considered early....the later Zetecs (w/VCT) are considered late.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 40 |
I will hook it up as specified in the early diagram. And let you know how it goes.
Cylinders 1 and 4 are already swapped compared to the original Motorcraft part (early and late) so I know hooking it up in the same way as the original part is not going to work.
Thanks guys!
Tom
Posts: 40 |
Everything worked like a charm, no more misfires! Thanks guys.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Not a problem.
Hector
257HP/259TQ
160HP/141TQ
Posts: 3,465 |
Originally posted by LoCoZ: You would be considered early....the later Zetecs (w/VCT) are considered late.
did you know our coil pack has been in use on the escort since 1991
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by ZetecRacing: Originally posted by LoCoZ: You would be considered early....the later Zetecs (w/VCT) are considered late.
Also it is listed in some catalogs as a coil pack for a 8 cylinder?
Hector
257HP/259TQ
160HP/141TQ
Posts: 21,653 |
As it's used on some Ford V8s (but two of them),, wow we all know the same crap.
98.5 SVT
Posts: 3,465 |
aka ZetecRacing
