#832951 01/02/04 03:51 AM
9
98csvt Offline OP
9
Has anyone put a trailer hitch on their SVT? How much weight does it hold? I want to pull two jet skis but my only vehicle choices are a Grand Am GT, a 85 CRX, or my 98 CSVT.
'98 Contour SVT (silver) Flip trunk, Pioneer head unit and 4-way 6x8s,working on shaving trunk of reflector and reverse lights, finishing subwoofer box, molding side skirts into car. No power mods.
#832952 01/02/04 04:22 AM
N
N
look in your owners manual. I believe the Tour is not recommended for towing anything, especially an SVT.
I could be wrong however. My car before I bought it had a plug for a trailer that someone spliced into the brake lights....
#832953 01/02/04 04:27 AM
9
98csvt Offline OP
9
I don't have an owners manual. Can someone let me know? Thanks.
#832954 01/02/04 04:45 AM
id say tow it with the grand am
do you got the 3.4L in it?
its got more torque down low than the duratec but runs out of steam up top
also, its a grand am! they are a dime a dozen
dont beat up the svt if you dont gotta
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
#832955 01/02/04 04:54 AM
People have done it, and it's definitely a capable towing car for real small trailers,etc., but really use the grand am, or for a joke, use the honda.
#832956 01/02/04 05:12 AM
There's a trailer hitch and wiring on my CSVT - came that way when I bought it. Don't have a clue what it towed, don't really care since I've beaten on it for 32k+ miles since I got it and it's still running like new at 138k miles.
From the '99 Contour owner's manual:
TRAILER TOWING
Your vehicle is capable of towing a
trailer of up to a maximum of
454 kg (1 000 lbs) gross trailer
weight with a maximum tongue
load of 45 kg (100 lbs). It should
also have 2.3 sq. meters (25 sq.
feet) or less frontal area. Do not
drive faster than 72 km/h (45 mph)
while towing a 454 kg (1 000 lb)
trailer.
Your vehicle does not come from
the factory fully equipped to tow.
No towing packages are available
through Ford or Lincoln/Mercury
dealers.
Trailer towing puts additional loads
on your vehicleâ??s engine, transaxle,
axle, brakes, tires, and suspension.
For your safety and to maximize
vehicle performance, be sure to use
the proper equipment while
towing.
The 2000 SVT supplement doesn't say anything about towing.
The owner's manuals are available free online as PDF files at Ford's Qualty Care Service webpage under "glove box manuals". They don't have the '98 or '99 SVT supplement but it's basically the same for all years, except to show power differences and color combos available.
Scott
Troll! '99 BMW 328i
#832957 01/02/04 07:25 AM
My SVT has a "Hidden Hitch" on it. It came with it when i bought it. I have no idea what they towed with it. I was gonna take it off right away, but I found when I pulled the cover off it and looked at it, that the bottom of the bumper had a small notch cut into it for the hitch to fit through the opening. So now its a matter of removing it and also repairing my bumper, and oh yeah, gettin the plastic grill to go back in there. I just know its not stayin on there forever cause I hate it.
#832958 01/02/04 09:46 AM
I would assume the 98 Contours are similar to the 99 Contours.... (could be wrong, as far as I know, they are similar) a 1999 Owners manual is located at www.fordfleet.com
Or click here for the full URL:
https://www.fleet.ford.com/maintenance/owners_manuals/Small_Cars/Contour.asp
Former owner of a 1995 Ford Contour GL w/ 2.0L ATX Proud owner of a 2005 Ford Taurus SE 3.0L V6 Vulcan --Looking for Commodore stuff (Drives, Units, Amiga, games, etc)If anyone has any of this laying around and wants it gone, lemme know --
#832959 01/02/04 05:07 PM
I have a 99 SE with a hitch. The weight figures given before are correct and it should tow just fine. I've had no problems. The only thing that may interfere is the rear bumper is lower on SVT and will need to be notched with most after market hitch systems. At the cost of a replacement bumper make sure that you want to put it on the SVT before you commit.
RVM Short Shifter RVM Intake Pipe Full Kenwood System NX Neons "If you can read this, thank a teacher; If you are reading this in english, thank a soldier"
#832960 01/03/04 04:06 AM
What's a pair of jet skis (with fluids) and a trailer weight anyways? I've got a pair of snowmobiles that weight about 600lbs/each [wet] and an aluminum trailer. I'd estimate their combined weight just shy of 2000lbs. A pair of jet skis and a trailer wouldn't be too far off that.
In short, none of the vehicles you listed would be a safe choice to pull that load. Do yourself a favor and either buy or rent (Hertz usually has Rangers for $20/day) something that can tow if you plan on using public roads. There's way too many bad things that can happen to yourself or others when asking a vehicle to perform beyond its capabilities.
Good luck, maybe sell that CRX and grab a cheap, little work truck? You'll find its uses are endless once you've got one.
1999 Ford Contour SVT #900/2760 (SOLD) 2005 Mazda 6s 2003.5 Mazdaspeed Protege 1998 Ford Ranger 4x4
