#831901 12/31/03 06:04 AM
altimit Offline OP
Hello all i need to know if i need to bleed my brakes. My brakes require quite a long throw to the grond to begin the braking process. i recently replaced the front pads. Are squishy braked a bleeding problem?
1999 Ford Contour SE Sport Duratech V6 Many mods...
#831902 12/31/03 07:12 AM
Yes, there is a how-to on the main part of the site. Look in the mods/how to section.
#831903 12/31/03 10:01 PM
Doesnt sound like it would hurt. Its an easy job anyways.
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
#831904 01/01/04 04:35 AM
altimit Offline OP
its not as bad now as it was the first day. But i'll do it anyway.
#831905 01/01/04 06:02 AM
You may also have the retainer springs improperly installed. This has been a common problem for first time do it yourself brake pad replacement.
It is also possible (depending on just how soft the pedal seems) that you just need to finish bedding in the new pads to the rotors. Even when everything is done perfectly, the pedal will be a little softer with new pads until they have been used a few days.
#831906 01/01/04 10:33 PM
altimit Offline OP
i thought the same thing on the the springs but then i took off the other wheel (when i had only done one side) and it looked the same. i think they just need to be done. Will they be HARD after i bleed them or just a little more firm?
#831907 01/03/04 05:30 AM
It should end up being quite firm. You may be able to make it firmer with stainless steel brake hoses if you really feel that you need that, but it is really unnecessary.
Moderated by  Andy W._dup1
