#829198 12/26/03 10:03 PM
BrianM Offline OP
What can be used to replace the two stock mufflers in the rear? I want to use Magnaflow, but don't know what size to get. And what kind of tips does magnaflow sell, that look close to stock? I'd appreciate any help, thanks.
Brian 1998 Contour SVT Born:5/22/97 Build #1199 "It's got mods...and it's black"
I don't have dual exhaust but I changed mine over and used a hooker aero chamber, lots of flow but not lots of noise.
If less is more, think how much more, more is...
Why? Did you want more sound? If you're after power, the stock mufflers might not be the most restrictive part of your system.
MSDS, SHO-shop Y, custom 2.5" catback; xcal2; 63mm TB, K&N 3530; Koni struts, Aussie bar; THaines forks, Quaife, SpecII, UR fly; DMD; Nima UD pullies; Stazi brakes; f&r Pole120 mounts. Just a daily commuter car. Silver '98 SVT E0 #3159
Replace the resonator with a straight through design.
Full body if noise is a concern. A bullet if it is not.
The rear mufflers should be replaced with Magnaflow part number #11124
The mufflers give a nice deep tone though they can be a bit "boomy" if you have no cats.
BrianM Offline OP
Thanks. I installed the BAT y-pipe with a high flow cat and a magnaflow 10425 high flow resinator. I wanted to replace the 2 mufflers in the back with Magnaflows. That part number you gave me allows for what kind of tips? Can i match a set of Magnaflow tips out that back that don't look like fart cannons? What do you recommend?
Any tips you want.
You will need to fabricate your own hangers as the stock muffler, hanger and tip is basically welded as one.
BrianM Offline OP
Any tips you want.
Thank you sir.
9
DemonSVT,
What is your recommendation for a 3L modded SVT that already has MSDS headers and Y-pipe, but stock from there back? Minimum noise for a daily driver.
Current plan: Take cat out, and go 2.75" to Maganaflow straight resonator. Stock from there back.
