been there done that....when i installed my svt bumper on my gl i ran into the same problem, cause ford thought it a good idea somewhere along the lines to CHANGE the size of the screws so mine didnt fit..... so this is what i did....
you get yourself a good set of locking vise-grips, a 5/16" bolt and lock nut...about an 1 1/4" long or so....there is actually enough space for you to lock down on the nut and slide it up inside the bumper and then tighten the bolt down from inside the wheel well....works well if you take the rear wheel and wheel liner out....great fix too....from the outside it looks factory! hth.....
-chris- 96 gl: 18" adr reactions, SVT rear bumper & side-skirts, Magnaflow exhaust, CTA Intake, ACCEL coil, 9mm wires, Kenwood, Blaupunkt, Sony Xplod Mobile ES, OBX pedals w/dead pedal, neons, bnmotorsports gauges, autometer monster tach, and ZAINO!
