I had to do nothing more than up the put a 15 amp fuse in the left and right headlight socket. Mine turned on for a second before they blew the fuse. I didn't reverse any polarization or anything.
Mine are a standard Hella ballast from a 9005 kit, I'm guessing its pretty standard between ballasts? Did you just plug everything in to the appropriate sockets on the bulb? Is the ballast grounded properly?
Drop me a PM, hopefully we can get them blinging! You'll need
when you get them plugged in!
