Jason Offline OP
I was wondering, before I start buying new stereo stuff, if there are any issues with the power antenna not working when the radio is replaced. Will it work with aftermarket units, or will I need to install a switch?
Jason
98.5 SE ATX
Jason
98.5 SE ATX
Anonymous
Unregistered
Anonymous
Unregistered
It'll work, you just might need an antenna adapter. You can get it where you get the wiring harness.
When I put mine in, it works fine. In fact, now the antenna stays down when you use the cd, and only up for radio. I like it better that way.
'00 Green SVT
K&N Drop-in
Sony X-Plod Head w/Polk Audio Spkrs
**Gone Honda Huntin'.....be back in 15.4!!
98 with Eibach Springs, Mille Miglia 17", Flowmasters. Daily driver.
_ _ _ ___________________ _ _ _
72 Datsun 510, Weber side draft, Roll Bar, 16" 300zx wheels, 300zx turbo break system. 300hp on the rear, weekend driver.
Moderated by  dnewma04_dup1
