Good Afternoon,
I have a 1998 Contour four cylinder/auto trans that's been failing to start when it's cold (I live in Michigan). I've attributed this to either the battery going or the alternator, possibly the belt. It's been on my list of things to do, but haven't gotten around to it. I only mention this because I'm not sure how it relates to my now, more serious problem.
Last night after dropping off some packages at Airborne Express, the Check Engine light came on. About 1/4 mile down the street I lost power coming from the engine, while it was still running. The engine began to vibrate and emit metallic noises - a low grinding. The car died completely about 20 seconds after.
Due to the battery/charging problems, the car wouldn't restart. After jumping it, I could get it to run if I fed it gas, but the engine continued to vibrate and make metallic clashing noises. Again, no power was being
delivered to the wheels. The car died soon after and refused to start at all.
I'd appreciate any ideas you all might have.
Thanks.
