There is a high-pitched whining noise coming from the engine compartment that I am having trouble localizing. It is common when the temp is below 30F outside. It happens at idle and when, for example, coasting in gear. If I didn't know it was in the front end I would swear on a stack of Bibles that it is the fuel pump dying. It likes to stall at idle as well, but very infrequently. I have searched around the forums and the best possibility I found is the power steering pump. All your guys'(gals too) thoughts are greatly appreciated.
Thanks,
-Drew
Khufu01
'00 Contour SE MTX 2.5L w/41K
