Posts: 79 |
Car would be hesitating and bucking when gas padle is floored, it won't do that if I easy on the gas,Fuel filter,cam shaft sensor and crank shaft sensor had been replaced,what else?
95se 5 speed
Posts: 95 |
Definitely not an expert here but sounds like plugs or plug wires could be at fault
98 Silver Frost EO
90 Grand Am H.O. Quad 4 300,000+ miles
Posts: 21,653 |
spark plugs, plug wires, clean injectors, air filter, pcv valve, engine.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 2,382 |
how long since the coil's been replaced, spark plugs, spark plug wires, cleaned throttle body??
on a side note, how is your wiring? Have you had the wiring harness replaced?
"Fear is the little death."
Muadib.
Posts: 834 |
Originally posted by Nate'sTour: how long since the coil's been replaced, spark plugs, spark plug wires, cleaned throttle body??
i have been having the same problem but everything you mentioned i replaced. The plugs are wires are new. Filter. In my situation i suspect it might be the fuel pump what do u guys think
HaHa You Watching me? Keep Watching
Posts: 16 |
Take this advice with a grain of salt, since my 95 Duratec is currently down with an ignition problem, but I had these same symptoms for about a year, and finally was able to correct it by installing the motorcraft OEM plugs. For the last 6 months since the install, I haven't had any of the symptoms you mentioned above.
It might be worth a try.
Geoff
Posts: 1,451 |
Vinny 2000 T-RED CSVT
MODS: 18" REV model 2 ST200 struts/Roush springs
CTA intake Pipe/K&N Filter
Dtec Heatshield
Optimized TB
True Duals w/ magnaflow mufflers/resonators
Posts: 31 |
Try unplugging the throttle position sensor and then drive the car. It will not run properly, but if those symptoms disappear, it's a good chance that is the problem.
Posts: 3,709 |
same symptoms as listed above and i have replaced the fuel pump/filter/sock filter/plugs/wires and she still bucks at under a 1/3 tank. The only thing i can think of is maybe the darn pump is going again? I replaced it once at 30K and again at 60K. I have been meaning to throw in some OEM plugs and wires when I get around to it, to see if that helps, but who knows.
Originally posted by Chickens: Religion can't do much for ashholes (unless you are an alterboy)
98.5 Se w/SVT mods
98 E0 SVT~ sold
Posts: 1,788 |
Unplug the MAF sensor and see if the engine runs better. If it does (it will throw a CEL), clean the sensor. If cleaning it does not restore the engine's performance, replace the MAF sensor.
Be certain you clear the KAM after cleaning or replacement.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
