I'm guessing the wire harnesses will likely be different. If you switch to an aftermarket wheel using a focus momo/sparco adapter, the turn signal indicators won't turn off by themselves though they would if you had an aftermarket wheel on a focus,, so right there is one difference... Though it could probably be made to work, just maybe some wire splicing needed.
