#822995 12/17/03 11:23 PM
Help me! I am having my new spring and struts installed soon and would like to do the front and rear strut mounts also. Problem is no one has them in stock so its a "special order" and i want the parts before they start ripping my car apart. I asked for price quotes and i seem to get something different everytime.
napa (first call)
front ~20 each
rear ~40 each
stealership (first call)
~28 each (front and rear)
napa (second call)
front ~40 without bearing/~82 with the bearing, but have to these from the dealership
rear "we have none on record" (as if they are none existant)
stealership (second call)
are they rubber or metal?
front ~85 (dont know if thats with bearing or not)
rear ? (never got a definitive answer)
Can someone tell me what exactly it is i need (part numbers would be nice)? A description?...i read somewhere the front is rubber and the rear is metal, but i dont know what to believe now. Do i need bearings...how do you know they are bad without taking them out first?
I dont mind spending the money but i wanna spend wisely.
Help please!!!
b0x @dm1n
b0x @dm1n
What do you mean by strut mounts? Struts hats maybe? If so check with BAT.
-Andy
Andy W. The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
whatever these are?
I was goin to order them from spmotorsports but i got a better deal on the spring and struts. now i have the springs/struts and was told i should be able to find mounts locally, but im not having much luck.
b0x @dm1n
b0x @dm1n
OK..OK..I ordered them from BAT.
I was familiar with place, but I was tryin to get them locally since im short on time. Better safe then sorry! These guys are more familiar with our cars then the average joe who picks up the fone at napa or ford dealerships. I'll just have to front the cost for 2nd day shipping.
Thanks for at least responding to my post.
Let us know if they include the bearing. The fordpartsonline site shows the bearings (they call it a hub?) priced at $139 each.
'98 LS MTX
N
N
I replaced the strut bearings this summer when the ST200's went in. They were cheap at only $25 CDN each. The hats were all fine.
96LXV6 heavily un-modded due to family addition. 87Renault GTA convertible, chopped springs, Ford Premium Sound, but otherwise stock.
according to the guy i talked to at BAT the mounts do not come with the bearings. He said I would have to get them from the dealer, but doubts i would need them. So, Im gambling i wont need the bearings and if i do I hope the dealership has them in stock. I guess i can give them a call tomorrow to see if they have them.
I never got a price quote of $139 each with or without the bearings so i dont know what the case is there. Perhaps thats the price of both right and left?
I recently installed a much younger set of 99 SVT struts and springs on my 98 E0 SVT. I also installed the camber adjusting kits on the front at the same time. To make the job go faster when the installation was actually done, I purchased new upper parts to pre-assemble the front struts before taking the car apart.
The camber adjusting kit takes the place of the upper strut bushing (the part you had a link to). I also replaced the metal uper spring "hat" or retainer and the strut bearing.
The rears do not have strut bearings since the rears do not rotate from turning the steering wheel.
As I remember, the strut bearing is about $15.00 to $20.00 each. They don't give much trouble on Contours, but there is a lot of labor involved to pull the strut down and replace them.
If you are lowering the car or have a lot of negative camber to begin with, the camber adjusting kits are a real life saver and well worth installing at the same time.
You can find a discussion about the effects of lowering the car on camber and see the camber kits at BAT www.batinc.net You can also find them at SP Motorsports as well as many auto parts stores. They are made by Specialty Products. I bought mine from Fast Undercar.
JIM,
Did you purchase the bearings from Fast Undercar too or did you get them from the dealer or local parts store? Do you know the part number for the bearing?
'98 LS MTX
