Page 2 of 2 1 2
Oh I almost forgot, The dip **** only sent me to screws for connecting the couplings together, can I use the stock screws or should I go out and buy the same type of screws he sent with locking nuts?
98 'tour silver
KKM
svt exhaust
svt wheels
stereo mods=kenwood head unit
alpine amps installed
12" kicker comp vr sub
purple calipers
www.angelfire.com/realm2/silverbullet/contour.html
http://members.sounddomain.com/silverbullet02
Mods to come!
purple neons
marker lights
PUTER chip
svt body kit
lowering job
PROBABLY IN THAT ORDER!
_ _ _ _ _ _ _ _ ___ _ _ _ _ _ _ _ _
I believe the stock screws will work- and by no means did you pi$$ me off. sorry- i was prolly edgy from my kid- I understand you pain there- green lights and all the cables- my 11 month boy goes for them everytime. Oh and my cordless mouse- he loves grabbin that from me and chewin on it- all this money i spend on his toys and he just wants to play with mine! I hope all works out on your filter- i would check into a new filter at orieley's before spendin the money at walmart for something to patch with- might as well just get a new one. or just patch it- I just hate going into wally world.
99 SE Sport 2.5 Duratec
Spruce Green Metallic..
Aesthetic Only.... For Now
...the closest I will ever get to having a Turbo will be the Gillete Mach 3 variety!!!
Administrator
Administrator
That hole is for the IAT sensor. Since you have a non-SVT, that's where you put that little sensor that is on your stock airbox. And reuse the old bolts. It doesn't look like you got ripped off at all.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
You got ripped man. I sold my KKM like new and I clean and re-oiled it for $70. I used it one year. I would send that thing back.
2000 Black SVT
SHO y-pipe / hi-flow cat
Large Cone Filter
B&M shifter
C&L 73 MAF
Pro-Flow Optimizer
Magnaflow Res
BAT Intake
Always looking forward to beating those coffee can wanna-be-fast imports.
Douchebag Racing: You dont need a racing team and trailer for a 14 sec. car.
Check it out: www.geocities.com/jcs9614
I bought mine used for $50. Almost brand new!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
Originally posted by PA 3L SVT:
$3 worth of 5 minute epoxy and you are all set.
Or $0.03 worth of duct tape! Personally I did what Chris said and plugged it with my IAT sensor.
98.5 SE Sport badgeless, MTX, KKM, SVT exhaust with resonator intact.
1985 Z51 Vette with many mods. Only used when the Tour appears to be outclassed.
why not read the directions from www.ctamotorsports.com then you will see why there is a hole there. it does serve a purpose.
Black '98 Mystique V6 atx. superchip,2 1/4" SVT style dual exhaust (custom) with no cat, high flow res, flo-pro mufflers with Ractive tips, 8.5" K&N conical with CTA adapter, UR Ultra Street Pulley, TH-fix. 215/45/17 Bridgestone RE730's on Konig Absolute wheels. Trans go Shift Kit, High stall torgue convertor, 24000 BTU transmission cooler.
OK I read the directions and looked at my cars filter box and I see why the hole is there but why do some people have to be stupid and just cut the hole instead of drilling it.
The filter has the hole but the hole is torn, will this effect the performance, it will close together but it is torn in two directions.
How much would a new filter cost, seeing how this is the main component of the kit I think it would be expensive. The reason I bought this was because It was supposed to give greater gains than the k&n, but if they are the same I can pick up a new filter if they make one, and does anyone make a filter that the IAT will plug in?
98 'tour silver
KKM
svt exhaust
svt wheels
purple calipers
Mods to come!
purple neons
marker lights
PUTER chip
svt body kit
lowering job
that hole is used for the crankcase ventilation on mine. not a big deal.
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t
1974.5 MG B GT
Page 2 of 2 1 2
