N
nasty1 Offline OP
N
Here's the dealio:
My clock randomly lights up. Sometimes its on somtimes its not.
My cruise buttons don't light up. They never have so I'm not sure if this is normal or what.
I apologize if these are common problems, the search isn't up and I already checked the FAQ.
Thanks for the help guys.
1998 Contour SVT Black with midnight blue interior http://img.villagephotos.com/p/2003-7/300749/contoursvt.jpg Build number to come soon!
H
H
There are no lights on the cruise control buttons. That would be a neat mod, though
For the clock, there is a replaceable bulb that you can get from http://www.partsexpress.com. Sorry, but I don't know which bulb to get since I haven't had one die on me yet. If its not the bulb you can try swiping a clock from a junked Contour or Mystique at the local salvage yard.
N
nasty1 Offline OP
N
Interesting that the cruise controls don't light up... I've had quite a few fords and this is the first one that doesn't have illumination there.
As far as the clock, I'm pretty sure its not a bulb. I mean it does light up every once in a while and it stays on for a good amount of time. Usually about a day.
H
H
Ahh, I see what you're saying. Have you pulled the clock out of the dash yet? I'd suspect a bad wire or something. You may be able to get away with some solder and a small length of wire.
I have actually got a set of Illuminated Cruise switches, made up by modding a Clock spring. The only issue is that there is then a 12v+ feed at the airbag , although insulated, its really not supposed to be there. I ran them for a few months before changing back, never got around to refitting them though
UK Ford Mondeo 2.5 V6, All the Toys, UIM Cover, Modded Secondaries. Now with Full Leather
The clock bulb is about $5 at the Ford dealer...
Look closely at the contacts for the bulb in the clock - they get weak with time. As for the cruise buttons, several ford products don't have illuminated buttons - for instance ragners with dealer installed cruise. Don't worry about the 12V feed through the clock spring. What do you think the horn and cruise buttons operate on?
