#821090 12/15/03 11:35 PM
I just got the BAT y-pipe the other day and when I got under my car, the existing catalytic convertor doesn't have an O2 Sensor, while BAT has a bung for a sensor. I'm thinking of just having an exhaust shop do it but I wanted to know if anyone else had this problem. Also does a hanger need to be made for the y-pipe since the stock one has a hanger.
'97 Contour gl V6 ATX sho shop CAI, DMD, rebuilt intake, metal waterpump Ford 9mm Racing Wires TH fix Wish I had a third pedal
#821091 12/16/03 01:10 AM
I have the the bat y-pipe. Take the o2 sensor from the manifold pipe (rear sensor it's on the pipe coming from the exhuast manifold closest to the fire wall)put never sieze on the threads and install on the new converter. You do not need hangers, when it goes together you will see what i mean. I have had mine on for awhile without any problems. I had the system welded instead of using the clamps. It gives a better seal and looks much better.
"we aren't punished for our sins, but by them" 2000 se sport tropic green/gray leather. V6,svt body kit and E1 wheels/Avon tech m500 rubber, many mods. 2003 Eddie Bauer Explorer V8 2001 Suzuki Bandit 1200S 1996 Mercury Sable
#821092 12/16/03 08:08 PM
Thanks for the info. Also, I was wondering if the new cat will fix my CEL that has been on for a while that supposedly is linked to a bad catalytic convertor. Could this be the O2 sensor itself or something else. Anybody got any thoughts?
