You can check the output of your alternator with a multimeter.
Just put the multimeter across your terminal cables while the car is running. You should have a reading around 14.4V
Do this with minimal load since you're only at idle. (I.E. radio off, headlights off, HVAC off)
Does your battery light come on at all?
Is the fading constant regardless of engine speed? Does it occur at idle, or when the engine is under load?
